Community Member
Unity Connection Redirect to VM Box Not Working
I have a CUCM BE 8.6.2 server.  Here is the call flow:
Inbound calls are routed to x1000.  After-hours, x1000 is forwarded to x1996 which is a Call Handler called Reception_CH.  While the Call Handler is playing, users have the option of dialing any extension to be transferred to that user (used x2400 for this example).  This works unless the end user at x2400 has done a CFWD ALL to voicemail.  In that case, users get the UCxn opening greeting "Hello.  Cisco Unity Connection Messaging System.  From a touch-tone phone...".
I believe problem is that the LastRedirectingId=1996 rather than 2400, though if that were the issue, I would expect it to replay the 1996 call hander rather than the opening greeting.  I have pasted the output of UCxn Port Status Monitor below.  This is for an inbound call to x1000, while x1000 is CFWDALL to x1996.  After getting the call handler at 1996, I dialed 2400 and received the "wait while I transfer your call", followed by 2 beeps (Tone on Hold), then the opening greeting.
I have the CUCM service parameter "Display Original Calling Number on Transfer from Cisco Unity" set to TRUE
I have the UCxn messaging parameter of "Use Last (Rather than First) Redirecting Number for Routing Incoming Calls" CHECKED
Any help would be greatly appreciated.
Remote Port Status Monitor Output:
02:30:48, New Call, CalledId=1000,  RedirectingId=1000,  Origin=16,  Reason=8,  CallGuid=6BA7F904B7FF432CB570543A08665791,  CallerName=Trunk 10,  LastRedirectingId=1996,  LastRedirectingReason=8,  PortDisplayName=CallManager-1-005,[Origin=Unknown],[Reason=Forward Unconditional]
02:30:48, AttemptForward
02:30:48, State - AttemptForward.cde!Dummy
02:30:48, Event is [NULL]
02:30:48, PHTransfer
02:30:48, State - PHTransfer.cde!LoadInfo
02:30:48, Event is [TrueE ass=MsoNormal style='text-indent:.5in'>02:30:48, PHGreeting
02:30:48, State - PHGreeting.cde!PlayGreeting
02:30:48, Call answered if needed
02:30:48, Playing greeting for Call Handler:  Reception_CH
02:30:54, DTMF received [2]
02:30:58, DTMF added [400]
02:30:58, Event is [NULL]
02:30:58, PHTransfer
02:30:58, State - PHTransfer.cde!LoadInfo
02:30:58, Answer Phone if needed
02:30:58, Event is [FalseEvent]
02:30:58, State - PHTransfer.cde!CheckPlayTransferIntro
02:30:58, Event is [TrueEvent]
02:30:58, State - PHTransfer.cde!PlayTransferIntro
02:30:59, Event is [NULL]
02:31:00, State - PHTransfer.cde!XferCall
02:31:01, Event is [HangupEvent]
02:31:01, State - PHTransfer.cde!DoHangUp
02:31:01, Idle
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Hi Kyle,
Good stuff
Here is a similar log from a test I just did from Call Handler 6198 and linking to 7001
which was on Call Forward All to VM. I did receive the proper Greeting for 7001;
07:28:33, New Call, CalledId=6198,  RedirectingId=6198,  Origin=16,  Reason=8,  CallGuid=F3A2F6D0C6344D30BE7B58BFED7077F1,  CallerName=Rob Huffman,  LastRedirectingId=6198,  LastRedirectingReason=8,  PortDisplayName=CallManager-1-002,[Origin=Invalid],[Reason=Invalid]
07:28:33, AttemptForward
07:28:33, State - AttemptForward.cde!Dummy
07:28:33, Event is [NULL]
07:28:33, PHTransfer
07:28:33, State - PHTransfer.cde!LoadInfo
07:28:33, Event is [TrueEvent]
07:28:33, PHGreeting
07:28:33, State - PHGreeting.cde!PlayGreeting
07:28:33, Call answered if needed
07:28:33, Playing greeting for Call Handler:  Rob Huffman 6198 transfer
07:28:40, DTMF received [7]
07:28:42, DTMF added [001]
07:28:42, Event is [NULL]
07:28:42, PHTransfer
07:28:42, State - PHTransfer.cde!LoadInfo
07:28:42, Answer Phone if needed
07:28:42, Event is [FalseEvent]
07:28:42, State - PHTransfer.cde!CheckPlayTransferIntro
07:28:43, Event is [FalseEvent]
07:28:43, State - PHTransfer.cde!XferCall
07:28:43, Event is [HangupEvent]
07:28:43, State - PHTransfer.cde!DoHangUp
07:28:43, Idle
** Now the only difference that I can note is that we do not have the setting
Checked in our set up. can you try without that setting.
Cheers!
Rob
"Everything is broken" - Bob Dylan
Hi Kyle,
Just to verify one thing here, does 2400 have voicemail set up on it? Once Unity
Connection transfers the call the control is assumed by CUCM so I'm seeing this
as expected behavior if 2400 has no voicemail account
Cheers!
Rob
Community Member
Rob,
2400 does have a voicemail box and if you call 2400 from another phone you get their VM message.  We have tested this with several users and it's not specific to 2400.  It happens with anyone who has their phone forwarded to VM.
Kyle
Hi Kyle,
Good stuff
07:28:43, Idle
Cheers!
Rob
Community Member
Unchecking that setting fixed it.
927
