Community Member
Unity Connection - Restricted or Unrestricted?
  Does anyone know of a way to tell if an installed Unity Connection is running restricted or unrestricted version of software?
Current active version is 8.0.3.10000-8
Everyone's tags (1)
Blue
Re: Unity Connection - Restricted or Unrestricted?
If you don't see the word "unrestricted" after the version on CCMAdmin  or OS Admin page when you login you're running the restricted version  which is the "normal" version with all security features available to be  enabled.
regards
Ronak patel
Rate helpful posts by clicking stars below the answer.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Community Member
Cheers Ronak, thanks for your assistance
Where can I find a Cisco
Where can I find a Cisco oficial information about how to verify if a version is restricted or unrestricted?
http://docwiki.cisco.com/wiki
http://docwiki.cisco.com/wiki/CUCM_Upgrades_and_Migrations_FAQ#How_to_tell_if_I.27m_running_a_restricted_or_unrestricted_image.3F
For the ISO images, you should be able to tell.
java
if this helps, please rate
www.cisco.com/go/pdi
Thank you for the reference,
Thank you for the reference, Jaime
1294
