Unity Connection Services Stuck
Hi Guys,
I have a unity connection server in which all the services are stuck at starting.
This happened after a server reboot after power failure . I have tried restarting the server but didnt help.
Requesting service status, please wait...
System SSH [STARTED]
Cluster Manager [STARTED]
Service Manager is running
Getting list of all services
>> Return code = 0
A Cisco DB[STARTING]
A Cisco DB Replicator[STARTING]
Cisco AMC Service[STARTING]
Cisco Audit Event Service[STARTING]
Cisco CDP[STARTING]
Cisco CDP Agent[STARTING]
Cisco CallManager Serviceability[STARTING]
Cisco CallManager Serviceability RTMT[STARTING]
Cisco Certificate Change Notification[STARTING]
Cisco Certificate Expiry Monitor[STARTING]
Cisco DRF Local[STARTING]
Cisco DRF Master[STARTING]
Cisco Database Layer Monitor[STARTING]
Cisco ELM Admin[STARTING]
Cisco ELM Client Service[STARTING]
Cisco ELM DB[STARTING]
Cisco ELM Server[STARTING]
Cisco Log Partition Monitoring Tool[STARTING]
Cisco RIS Data Collector[STARTING]
Cisco RTMT Reporter Servlet[STARTING]
Cisco Syslog Agent[STARTING]
Cisco Tomcat[STARTING]
Cisco Tomcat Stats Servlet[STARTING]
Cisco Trace Collection Service[STARTING]
Cisco Trace Collection Servlet[STARTING]
Connection Administration[STARTING]
Connection DB[STARTING]
Connection DB Event Publisher[STARTING]
Connection Directory Feeder[STARTING]
Connection License Manager Server[STARTING]
Connection SNMP Agent[STARTING]
Connection Server Role Manager[STARTING]
Connection Serviceability[STARTING]
Host Resources Agent[STARTING]
MIB2 Agent[STARTING]
SNMP Master Agent[STARTING]
SOAP -Log Collection APIs[STARTING]
SOAP -Performance Monitoring APIs[STARTING]
SOAP -Real-Time Service APIs[STARTING]
System Application Agent[STARTING]
>> Return code = 0
Cisco CDP[STARTING]
I have this problem too, did
I have this problem too, did you fix the problem?
Any solution regarding this
Any solution regarding this issue
I used the recovery disc.
I used the recovery disc. After the server rebooted, I had the same error. I then called TAC. We discovered there was DB corruption. The only way to resolve was to rebuild the server/cluster. Total process takes about an hour to an hour and a half.
1232
