Unity Connection SIP trunk integration vs alerting name
I have been implementing a Unity Connecion 8.6 with a CUCM cluster 8.6 via a SIP trunk.
The previous implemention of the Unity server was set up using voicemail ports;
When users used to call the voicemail pilot number, we were able to configure an alerting name on the vm ports, saying (to VoiceMail) for example.
I am looking for a solution for the new implementation via the SIP trunk. I just want users to see 'to VoiceMail' on their phone when they call the Unity Connection system.
Thanks for the help!
Best regards,
Antoine
I have found the solution:
If you want to dispaly a name such as Voicemail, etc you can change that in Unity Connection under Port Group --> Advanced Settings --> "Remote-Party-ID"
cheers!
Thanks for posting this
Thanks for posting this answer, just done my first CUC SIP integration and was annoyed when it displayed "unknown"
They should really include this in the deployment guide.
341
