03-17-2014 05:43 AM - edited 03-16-2019 10:08 PM
I'm trying to find an easier way to view inactive LDAP users in Unity besides viewing each user's page to see the "inactive" message. Is there a SQL query that'll point these out?
Unsing Unity 9.1 SU1
03-17-2014 08:15 AM
Hi Paul,
You can use the data dictionary to achieve this. I am not a CUC guy, but on CUCM, there is a table called "enduser" that will have the required details. I'm guessing it should be the same on the CUC as well.
try
admin:run sql select * from enduser where status=0
03-17-2014 08:54 AM
I can't find a Unity-specific data dictionary doc, and that query isn't quite right. The users in Unity are not the same design as CUCM, as you have the concept of "local", "LDAP-synched", and "CUCM-synched". I'm trying to find users that were LDAP-synched that are no longer active.
06-07-2017 04:33 AM
run sql SELECT * from enduser where status = '2'
if using putty, enable the logs to a file so you can see the table nicely
