Bronze
Unity Connection SQL query for "inactive LDAP users"
I'm trying to find an easier way to view inactive LDAP users in Unity besides viewing each user's page to see the "inactive" message.  Is there a SQL query that'll point these out?
Unsing Unity 9.1 SU1
Hi Paul,You can use the data
Hi Paul,
You can use the data dictionary to achieve this. I am not a CUC guy, but on CUCM, there is a table called "enduser" that will have the required details. I'm guessing it should be the same on the CUC as well.
try
admin:run sql select * from enduser where status=0
Bronze
I can't find a Unity-specific
I can't find a Unity-specific data dictionary doc, and that query isn't quite right.  The users in Unity are not the same design as CUCM, as you have the concept of "local", "LDAP-synched", and "CUCM-synched".  I'm trying to find users that were LDAP-synched that are no longer active.
run sql SELECT * from enduser where status = '2'
if using putty, enable the logs to a file so you can see the table nicely
183
