Unity Connection Sub-menues frozen
Hello
When I login to unity connection and click any menue it allows me open that menue  but when I try to go into any sub menue like  user ---edit  , it does not open the drop-down edit menue. I have tired Internet Explorer and Chrome. Any thoughts?
Asad Hanif
  • IP Telephony
VIP Purple
Hi Asad,
what is the version u are using ?
try Mozilla.
regds,
aamn
Unity connection 7.1
Bronze
As suggested above, Try Mozilla. Chrome will not work with UCxn versions under 9 (And I'm not sure about 9) and the latest update to IE is not working either. So either downgrade your IE, or go for Mozilla.
Gareth
Hello Asad,
What is the version of IE that you are using? Have you tried with Mozilla firefox?
Br,
Nadeem
Please rate all useful post.
Br, Nadeem Please rate all useful post.
VIP Purple
Hi Asad,
could be a bug.
As suggested by other members also , try mozilla
Cannot scroll through some drop down boxes with up/down arrow keys in IE
CSCsa97530
Symptom: Cannot scroll through dropdown boxes with the up/down arrow keys.
Conditions: For some browsers, the up/down arrow keys do not scroll through the list of options in a dropdown box. Instead of scrolling up/down the list, the first entry is immediately selected.
The specific dropdown boxes that exhibit this behavior are:
1. Run Reports For
2. Selected/All Entries
3. Rows per Page
Workaround: To improve the situation: 1. Use the computer's mouse to scroll through a list in a dropdown box. 2. If using a mouse is not a viable solution, we recommend using the Mozilla browser as it does not exhibit the described behavior.
regds,
aman
102
