unity connection System is temporarily unable
I've a UCCX 8.6.1.20000-109. One server. Registered to a CM cluster 8.6.2-20000-2.
I'm getting this error "System is temporarily unable to complete your call" while calling an extension on CM diverted to VM.
I've installed the IT Locale but used it before without any problem.
It always worked fine and suddenly stopped.
Do you have any ideas?
thanks
------- have a look to my blog lgrconsulting.com
  • IP Telephony
Everyone's tags (2)
Re: unity connection System is temporarily unable
Maybe the vm is full?
Did you check the status of the vm system?
Can you directly access the vm?
Hall of Fame Super Red
Hi there,
I'm 99% sure this has to do with the locale files. For the time being I
would remove them;
delete cuc locale (Cisco Unity Connection Only)
This command deletes the specified locale and all of the associated files and settings from Connection.
Command syntax
delete cuc locale locale-id
Parameters
locale-id represents the ID of the locale that you want to delete.
For a list of installed locales and their IDs, run the show cuc locales (Cisco Unity Connection Only) command. Be aware that locale IDs are case sensitive.
Usage Guidelines
Before you run this command, you must stop the Connection Conversation Manager and Connection Mixer services. After you run this command, you must restart the Connection Conversation Manager and Connection Mixer services.
Requirements
Command privilege level: 1
Allowed during upgrade: Yes
Example
The following example deletes the en-GB locale and all of the associated files and settings.
delete cuc locale en-GB
en-GB uninstalled
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/cli_ref/8_5_1/cli_ref_851.html#wp39459
Cheers!
Rob
"May your heart always be joyful And may your song always be sung May you stay forever young " - Dylan
Hello Rob,
I tried what you suggested but it didn't work.
I did found in the bugtoolkit what you mention but it was for Ucnx 8.5.
I think the problem was related with a subnet mask change I did.
Anyway I fixed it by reinstalling the whole system.
Many thanks
Deleting/Re-adding users in
Deleting/Re-adding users in CUC solved here.
Is not a good solution, but I didn't find any other.
1515
