Unity Connection time base VM boxes
I need help on unity connecion to configure time base greeting on user VM.
In Office hours user voice mail greeting should be " Hello i am away from my desk.
If you want to leave message than press one and press two to call our support number ".
If caller press one than caller should have option to leave voice msg. and for 2 call should forward to some support no.
In weekend vm messge would be " Our office hrs are XXX please press 1 to leave voice message"
Dinesh Joshi
1 ACCEPTED SOLUTION
Just configure the schedule accordingly and then the standard and closed greeting, be aware that you can only configure one set of caller input per VM box, you might want to mix TODs or routing rules if you need to reach different options with the caller input.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
java
java
Hi Jaime,
Thanks for your response. We used closed greeting and time schedule for this and it is working now.
Dinesh Joshi
143
