Unity Connection Transfer Options not working
Transfer options on the users are set to send to the extension.
calls are first sent to a UCCX AA and then transfered to the unity Directory Handler. However, when finding the name to dial it always transfers to the greeting instead of to the extension.
1 REPLY
Re: Unity Connection Transfer Options not working
Hi!
Have you checked you are using the "attempt transfer for" instead of the default "send to greeting for" ?
Teresa.
Regards, Tere. If you find this post helpful, please rate! :)
330
