04-30-2014 11:18 AM - edited 03-16-2019 10:38 PM
Client has forgotten the GUI password, there were several failed attempts to login. After that there were several attemps to change the password through CLI. Now when I try to reset the password I get the following error;
admin:utils reset_application_ui_administrator_password
New password:*
Confirm new Password:*
-------------------- utils reset_ui_administrator_password --------------------
Reset user interface password
2014-04-30 17:57:43,168 ERROR [ClassExecutionThread] cli.cmdResetPasswd - Error:: Unable to set Passwd
2014-04-30 17:57:43,168 ERROR [ClassExecutionThread] cli.cmdResetPasswd - Error:: Read Credential for cucadmin01 failed.
04/30/2014 17:57:43.165 : Update FAILED: code = 1, AUTHORIZATION FAILURE
Executed command unsuccessfully
With the many resets, we are unsure what the password is now. If anyone has encountered this issue please let me know what steps are needed to correct this.
AK
04-30-2014 08:07 PM
Hi AK,
you can follow the procedure
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unity-connection/68400-unity-conn-password-recovery.html
Suggest keeping alphanumeric password of at least 8 characters in length with special characters like @, #
regds,
aman
05-01-2014 09:49 AM
I can see there is a bug with UCXN version 2 and 7
05-01-2014 09:35 AM
I am having this problem now as well.
In the past if memory serves,I had to do a reboot on Unity Connection for this command to work. I am going to attempt it this evening. I think there might be a bug
New password:*
2014-05-01 13:31:55,544 ERROR [ClassExecutionThread] cli.cmdResetPasswd - Error:: Unable to set Passwd
2014-05-01 13:31:55,545 ERROR [ClassExecutionThread] cli.cmdResetPasswd - Error:: Read Credential for ucadmin failed.
05/01/2014 13:31:55.543 : Update FAILED: code = 1, AUTHORIZATION FAILURE
admin:show version active
Active Master Version: 8.6.2.20000-2
Active Version Installed Software Options:
No Installed Software Options Found.
I believe the link posted above is only applicable for older versions of Unity Connection that were Windows based.
