Unity Connection : unable to retrieve messages from alternate extension
I have  created a shared mailbox number 1118 for extensions 1501 and 1502 , and setup alternate extension for it as 1501 and 1502. 1501 and 1502 don't have individual mailboxes in unity conenction, but are set as alternate extensions to 1118.
Whwn a voice message  is left for 1118, the MWI lights propoerly on 1501 and 1502 phones.. but problem is while retrieving messages.
To retrieve message from 1502 , when the messages button is pressed, unity doesn't prompt the user for a PIN,
Instead it gives a message " cisco unity messaging system, from touchtone system , you may dial an extesnison, for directory services pree * , or ask your operator for assistance...
Can somebody suggest, how this can be fixed... I seems unity is not recognising 1502..
When I run the port monitor tool, I notice correct port group is being selected.
  • IP Telephony
Hi Rajesh,
This is default behavior. If you are pressing the messages button from the phone with extensions 1501 or 1502, the unity connection is looking for a mailbox with either one of those extensions as its primary extension. Since there are none, you get the default unity connection opening greeting.
However, if you leave a message for extension 1501 or 1502, and press the messages key on the phone with extension 1118, you will be able to access the messages for 1501 or 1502 as it is a shared mailbox that has 1118 as the primary extension.
If you want to get these messages when checking from the phones with ext 1501 or ext 1502, you will need to hit the messages key, then press * when the unity connection greeting comes on, enter your id and # (in this case it will be 1118# as this is the parent extension for the mailbox you are trying to access), and then the pin for ext 1118 mailbox.
Hope that makes sense.
Hope that helped, if so please rate.
Hall of Fame Super Red
Re: Unity Connection : unable to retrieve messages from alternat
Hi Rajesh,
In addition to the good notes from Kenneth (+5 "K" )
In our system the Alternate extensions can access the system by just entering the PIN
as you desire. The one thing I noticed in your query is that you mention the MWI lamps
are turned on on 1501 & 1502 when a message is left on 1118. This is not the standard
behavior for Alternate extensions and leads me to believe that perhaps 1501 & 1502 have
been set as Alternate MWI but not actual Alternate extensions.
Adding Alternate Extensions
You can add alternate extensions by updating user accounts one at a  time, or you can update multiple user accounts at once. Do the  applicable procedure. Note that you cannot add alternate extensions on a  user template.
To Add an Alternate Extension to an Individual User Account
To Add Alternate Extensions to Multiple User Accounts in Bulk Edit Mode
Step 1 In Cisco Unity Connection Administration, find the user account for which you want to add an alternate extension.
Step 2 On the Edit menu, select Alternate Extensions.
Step 3 On the Alternate Extensions page, select Add New.
Step 4 On the New Alternate Extension page, in the Phone Type list, select the applicable phone.
Step 5 In the Display Name field, enter a description of the alternate extension.
Step 6 In the Phone Number field, enter the phone number of the alternate extension.
Step 7 Select Save.
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/8x/user_mac/guide/8xcucmac040.html#wp1458710
Here is what a "working" call from 8899 which is the "Alternate extension" under the parent 7001
looks like (using rPSM);
07:49:06, New Call, CalledId=8700,  RedirectingId=,  Origin=16,  Reason=1,  CallGuid=98456E48AFE143EE9018621A806F3312,  CallerName=Alumni Homecoming,  LastRedirectingId=,  LastRedirectingReason=1024,  PortDisplayName=CallManager-1-001,[Origin=Invalid],[Reason=Invalid]
07:49:06, AttemptSignIn
07:49:06, State - AttemptSignIn.cde!Dummy
07:49:06, Event is [NULL]
07:49:06, SubSignIn
07:49:06, Subscriber Sign-In
07:49:06, State - SubSignIn.cde!AnswerPhone
07:49:06, Event is [TrueEvent]
07:49:06, State - SubSignIn.cde!AuthenticateUser
07:49:06, -->SubAuthenticate
07:49:06,         State - SubAuthenticate.cde!TryCounter
07:49:06,         State - SubAuthenticate.cde!GatherID
07:49:06,         Event is [FalseEvent]
07:49:06,         State - SubAuthenticate.cde!LoadSubscriberMinimalData
07:49:06,         State - SubAuthenticate.cde!GatherPIN
07:49:06,         -->SubAuthenticatePW
07:49:06,                 State - SubAuthenticatePW.cde!ValidatePwd
07:49:14,                 Subscriber sign-in successful. Alias - rhuffman. Extension - 7001. Caller Id - 8899.
07:49:14,                 Event is [TrueEvent]
07:49:14,                 State - SubAuthenticatePW.cde!ReturnAuthenticated
07:49:14,                 Event is [Authenticated]
07:49:14,         <--SubAuthenticatePW
07:49:14,         State - SubAuthenticate.cde!ReturnAuthenticated
07:49:14, State - SubSignIn.cde!RunSignInUtil
07:49:14, -->SubSignInUtil
07:49:14,         State - SubSignInUtil.cde!CheckAccountLocked
07:49:14,         Event is [FalseEvent]
07:49:14,         State - SubSignInUtil.cde!CheckExpiredAndNew
07:49:14,         Event is [NULL]
07:49:14,         State - SubSignInUtil.cde!CheckForExpirationWarning
07:49:14,         State - SubSignInUtil.cde!CheckForAdminConversation
07:49:14,         State - SubSignInUtil.cde!CheckAlternateGreeting
07:49:14,         State - SubSignInUtil.cde!CheckForLeaveMsg
07:49:15, <--SubSignInUtil
07:49:15, Event is [FalseEvent]
07:49:15, State - SubSignIn.cde!RunSignInUtil_default
07:49:15, Event is [NULL]
07:49:15, State - SubSignIn.cde!RunNextConv
07:49:15, -->SubMenuOpt1
07:49:15,         Subscriber Mailbox (Rob Huffman)
07:49:15,         State - SubMenu.cde!MapTemplate
07:49:15,         State - SubMenuOpt1.cde!SetSubConversations
07:49:15,         State - SubMenu.cde!RunMsgCount
07:49:15,         -->SubMsgCount_OptConv1
07:49:15,                 State - SubMsgCount.cde!CountMailboxMessages
07:49:15,                 State - SubMsgCount.cde!GetMailboxStatus
07:49:15,                 Event is [YesEvent]
07:49:15,                 State - SubMsgCount.cde!SayHello_WithShortCut
07:49:17,                 Event is [NULL]
07:49:17,                 State - SubMsgCount.cde!RunCheckBroadcastMsg_WithShortCut
07:49:17,                 -->SubBroadcastMessage
07:49:17,                         State - SubBroadcastMessage.cde!CheckForBroadcastMessage
07:49:17,                 <--SubBroadcastMessage
07:49:17,                 State - SubMsgCount.cde!AnnounceMsgGreeting_WithShortCut
07:49:17,                 State - SubMsgCount.cde!CheckPurgeDelMsg
07:49:17,                 Event is [FalseEvent]
07:49:17,                 State - SubMsgCount.cde!AnnounceMsgCount
07:49:21,                 Event is [TT1Event]
07:49:21,         <--SubMsgCount_OptConv1
07:49:21,         State - SubMenu.cde!RunNewMsgStack
07:49:21,         -->SubNewMsgStack
07:49:21,                 State - SubNewMsgStack.cde!CheckTotalMsgCount
07:49:21,                 Event is [NULL]
07:49:21,                 State - SubNewMsgStack.cde!AnnounceMsgs
07:49:23,                 Event is [NULL]
07:49:23,                 State - SubNewMsgStack.cde!CheckOfferMsgTypeMenu
07:49:23,                 Event is [FalseEvent]
07:49:23,                 State - SubNewMsgStack.cde!PlayMsgStack
07:49:23,                 -->SubMsgPlay_OptConv1
07:49:23,                         State - SubMsgPlay_Custom.cde!MapTemplate
07:49:23,                         State - SubMsgPlay.cde!MsgRoot
07:49:23,                         State - SubMsgPlay.cde!ValidMsgStreams
07:49:23,                         State - SubMsgPlay.cde!MessageHeaderDispatchCheck
07:49:24,                         Event is [TimeoutEvent]
07:49:24,                         State - SubMsgPlay.cde!MessageBody
07:49:31,                         Event is [TimeoutEvent]
07:49:31,                         State - SubMsgPlay.cde!MessageFooter
07:49:31,                         State - SubMsgPlay.cde!MsgMenu
07:49:47,                         Event is [TT7Event]
07:49:47,                         State - SubMsgPlay.cde!SetExitProperties_Delete
07:49:47,                         Event is [NULL]
07:49:47,                         State - SubMsgPlay.cde!MessageExit_CheckMarkNew
07:49:47,                         Event is [FalseEvent]
07:49:47,                         State - SubMsgPlay.cde!MessageExit_CheckMarkRead
07:49:47,                         Event is [TrueEvent]
07:49:48,                         State - SubMsgPlay.cde!MessageExit_MarkRead
07:49:48,                         Event is [TrueEvent]
07:49:48,                         State - SubMsgPlay.cde!MessageExit_CheckToggleUrgency
07:49:48,                         Event is [FalseEvent]
07:49:48,                         State - SubMsgPlay.cde!MessageExit_CheckUndelete
07:49:48,                         State - SubMsgPlay.cde!MessageExit_RouteToAction
07:49:48,                         Event is [ExitDelete]
07:49:48,                         State - SubMsgPlay.cde!CheckUseDelItmFldr
07:49:48,                         State - SubMsgPlay.cde!GetMailboxStatus1
07:49:48,                         Event is [YesEvent]
07:49:48,                         State - SubMsgPlay.cde!MsgDelConfirmCheck
07:49:48,                         State - SubMsgPlay.cde!DeleteMsgWithoutConfirm
07:49:48,                         State - SubMsgPlay.cde!MsgDeleted
07:49:48,                         Event is [NULL]
07:49:48,                 <--SubMsgPlay_OptConv1
07:49:48,                 State - SubNewMsgStack.cde!AnnounceEndOfMsgs
07:49:50,                 Event is [NULL]
07:49:50,                 State - SubNewMsgStack.cde!MsgExitCount
07:49:50,                 State - SubNewMsgStack.cde!CheckTotalMsgExitCount
07:49:50,         <--SubNewMsgStack
07:49:50,         State - SubMenu.cde!ResetMsgCount
07:49:50,         State - SubMenu.cde!COSAndMsgCount
07:49:50,         State - SubMenu.cde!CheckMailStoreMounted
07:49:50,         Event is [FalseEvent]
07:49:50,         State - SubMenu.cde!CheckJumpToNewMessages
07:49:50,         State - SubMenu.cde!AnnounceMenu
07:49:59,         Event is [TTStarEvent]
07:49:59,         State - SubMenu.cde!SubConvExit
07:49:59,         Event is [HangupEvent]
07:49:59, <--SubMenuOpt1
07:49:59, Idle
Cheers!
Rob
"Always movin' ahead and never lookin' back" - Springsteen
"May your heart always be joyful And may your song always be sung May you stay forever young " - Dylan
Actually, an Alternate Extension configuration (by itself) should behave as Rob noted above.  This is what an alernate extension does:
When you specify the phone number for an  alternative extension, Connection handles all calls from that number in  the same way that it handles calls from a primary extension (assuming  that ANI or caller ID is passed along to Connection from the phone  system). This means that Connection associates the alternate phone  number with the user account, and when a call comes from that number,  Connection prompts the user to enter a PIN and sign in.
However, an Alternate Extension does not affect MWI behavior.  To enable MWI for an extension other than the primary extension assigned to the mailbox, you would have to configure an alternate MWI extension.  In your case, it sounds like this is the configuration you have (Alternate MWI and not Alternate Extension).
The other thing to look at once the Alternate Extension is in place is to make sure that the caller ID is being passed correctly so you would want to ensure that you assign the proper VM profile to the lines.
Hailey
Please rate helpful posts!
Saw this last week before all the replies but failed to find a moment to get back here.  Great answers up above.
I was in a similar situation last year but decided to make some changes for one of my departments.  they have a main DID number to the department which resides on a call-handler.  at 2 points in the call tree the callers have the option to '0' out to someone in the department.  Because the department is very busy and understaffed the "Message Recipient" on the "Edit Message Settings" page of the call handler is set to Distribution List  The distribution list then notifies both users standard mailboxes that a message is available and the MWI is lit.  This gives the user who is the first one to listen to the message the ability to mark is as read, unread or delete it.
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/8x/administration/guide/8xcucsag230.pdf
I'm not sure if this is viable in all versions of Unity or Unity Conection, we are running 8.6.  I believe this also helps limit the number of voice mail licenses you use.  Which may only matter if you have a similar setup for many departments.
856
