Community Member
Unity Connection upgrade - what happens to messages between upgrade and switchover?
Hello All,
I am getting ready to do a Unity Connection upgrade from 7.x to 8.x.  Its been awhile since i did a unity connection upgrade.  I recall when i did the switchover from one partition to the other it took about 45 minutes.  If I remember right, i believe it was because it had to move all the voicemail messages that occurred between the upgrade and switchover.
so my question to everyone is.  Is that still the case?  If i upgrade a unity connection box on Friday morning and do a switchover on saturday afternoon will the switchover take hours to move all the messages left in that time period?
if thats the case i'll do the upgrade closer to when we can do a switch version.
thanks
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: Unity Connection upgrade - what happens to messages between
Hi "K",
The messages are actually stored in a common Partition and are not copied
across. The messages that accumulate between the Upgrade time and the time you
do the "Switch-Version" should not impact to overall time needed to complete the
change
Here's a clip that speaks to this;
Data from the partition where the older version is installed is copied to the partition where the newer version is installed. If changes to the database schema require updates to the format of data, that occurs in this step. Note that messages are stored in a common partition, so they are not copied.
Upgrading Connection 7.x or 8.x Software to the Shipping 8.x Version
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/8x/upgrade/guide/8xcucrug009.html
Cheers!
Rob
Hi "K",
change
Cheers!
Rob
Community Member
thanks Rob!
is this also the case with a High Availability Unity Connection cluster?
Hi "K",
Yes, this info is applicable to an Active-Active cluster
Cheers!
Rob
457
