Unity Connection Upgrade
lyle.stevens
I have an MCS 7815 running Unity Connection 1.X and am looking to upgrade to 7.X and can not locate any upgrade guides as this server is EOL. Has anybody done this or know where I could locate an upgrade guide? Thanks.
William Bell
First, you need to confirm whether you platform is compatibile with the release of Unity Conneciton you are targeting.  Check this link out for specifications:
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6789/ps5745/ps6509/data_sheet_c78-491743.html
You should also bookmark this link for future reference: http://www.cisco.com/en/US/products/ps6509/products_data_sheets_list.html
In regards to the upgrade process, please refer to this document:
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/7x/upgrade/guide/7xcucrug010.html
HTH.
Bill
Please rate helpful posts.
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
Thanks for the help.
