09-23-2013 03:19 AM - edited 03-16-2019 07:29 PM
Dear
when i press voice button on the phone i need to hear arabic language voice mail prompt for some phones , and other phones i need to hear a default engish language prompt , shall i need to add multilanguage .cop software on the unity ? from where can i get ? can you send to me link for that , becasue i need english and arabic language on unity it depends on related users .
thanks
09-23-2013 03:32 AM
You will need to install the language cop file that you need and then you need to configure two different voice mail templates, english and arabic. On the default language you need to select arabic for arabic template and english for english template. You then need to assign users to their voice mail templates depending on which language you want them to use
NB: If you have already added the users, you need to manually change the language for them.
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
09-23-2013 04:37 AM
dear aokanlawn
what is the name of cop file ? do have link ?
thanks
09-23-2013 04:51 AM
Cisco Unity Connection Locale Installer 9.1(0) - Arabic (Qatar)
uc-locale-ar_SA-9.1.0.1-32.cop.sgn
Refer to this similar thread
https://supportforums.cisco.com/thread/2223860
You can download from here..
09-23-2013 03:39 AM
Hi.
you can change the language per user mailbox on unity modifying user basic info.
Remember English is the default UCNx Language and is always available.
Carlo
Please rate all helpful posts
"The more you help the more you learn"
09-23-2013 04:35 AM
only there is english langauge per user maibox , there is no arabic
09-23-2013 04:37 AM
Have you installed the language pack?
09-23-2013 04:50 AM
In addition to what Mr. Aok has said[+5] ,I think u can refer the link for downloading:
regds,
aman
