Unity Connection version 9.x / Issue with users
Hi to all
We are experiencing  one issue with CUC and i need your input pls
When i tried to delete a user i recieved the below error
Do you have a workaround about that?
Error: java.lang.NullPointerException
""The Most Successful People Are Those Who Are Good At Plan B""
Please rate all useful posts Regards Chrysostomos ""The Most Successful People Are Those Who Are Good At Plan B""
1 ACCEPTED SOLUTION
Silver
Re: Unity Connection version 9.x / Issue with users
Hello chrysostomos1980,
Here is a list of commands to run as it did not work with the extension:
First determine the object id, there are several ways to do so if one does not work or fails continue with the next command to find it out:
run cuc dbquery unitydirdb SELECT ObjectId from vw_subscriber WHERE Alias = 'davidDapeck'
run cuc dbquery unitydirdb SELECT ObjectId from vw_globaluser WHERE Alias = 'peckdaDavid'
run cuc dbquery unitydirdb SELECT ObjectId from vw_alias WHERE Alias = 'examplealiasname'
TO DELETE  (examples below):
run cuc dbquery unitydirdb execute procedure csp_subscriberdelete(pObjectId = 'objectid ofuser')
run cuc dbquery unitydirdb execute procedure csp_aliasdelete(pobjectid='ae10df94-3601-4037-3333-fc967ccda961')
run cuc dbquery unitydirdb EXECUTE PROCEDURE csp_UserDelete (pObjectId='ae10df94-3601-2222-8084fc967ccda961')
run cuc dbquery unitydirdb select * from tbl_alias where object_globaluserobjectid = 'dd662797-ee1a-4b5b-1111-845aa9c60cd3'
DELETE USER WITH PKID>>
run sql select userid, pkid from enduser where userid = '<_user_alias>'
run sql SELECT fkenduser, fkappserver  FROM enduserappservermap WHERE fkenduser = '83215248-6288-4444-87e2-db5efcca3e98'
run sql delete FROM enduserappservermap WHERE fkenduser = '83215248-6288-446d-87e2-db5efcca3e98' and fkappserver = '67285943-ff95-4f4f-88c6-e6206cf23551'
If none of those work due to a reference from the subscriber mapped elsewhere run:
Used the following command to find subscriber references:
run cuc dbquery unitydirdb select * from vw_subscriberreference where objectid='user_object_id'
That's the stack i have in the meantime, check them out and let me know results.
-sajor kcep divad
Have you tried a differnet browser?  I have had such issues with IE11 and Java 7.
Silver
You can also try deleting the user via CLI by the extension:
DELETE USER BY EXTENSION
example of extension 1616
run cuc dbquery unitydirdb delete from tbl_DtmfAccessId WHERE DtmfAccessId ='1616'
-divad sajor kcep
Hi Guys
Thank you for the reply
I  have tried throught CLI
Result looks like this:
admin:run cuc dbquery unitydirdb delete from tbl_DtmfAccessId WHERE DtmfAccessId ='0105'
ACE_File_Lock::ACE_File_Lock: Permission denied /dev/shm/CCM_GENstatusLock_0
Rows: 1
Do you have any idea about that?
Silver
-sajor kcep divad
444
