Unity Connection Viewed only
I have Cisco Unity Connection version: 8.5.1.10000-206. My customer asked for user who can access the system just for viewing the user with mailboxes.
Question is?
Can I create a customized ROLE and assign it under the user.
Please Advise.
Ali Nasser
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: Unity Connection Viewed only
right.
Chris
Ali Nasser,
Unfortunately the pre-configured roles are hard coded and privileges cannot, new ones cannot be created either.  You would have to pick from one of the predefined roles, each one of them has some modify/create privilege.
Sorry, HTH,
Chris
Dear Chris,
Thanks for your reply.
But in this case if you create any new user, the user can change the password of the admin user, also he can change the password of mailboxes etc....
Is there any way that the Call manager can control the access to unity connection?
Ali Nasser
CUCM cannot control admin access to UCON , it is all defined via the UCON roles.
Chris
Its seems that no way to create a Read only user.
Thanks Chris.
Ali
right.
Chris
243
