Unity Connection Voice Mail Issue
I have a weird Unity Connection Voice Mail issue and would appriciate any help i can get. Many thanks in advance.
I have Unity connection 7.0 and CUCM 7.0 integrated in a lab enviroment and here is what happens.
When I place a call internally say from 2001 to 2002, things work as expected, 2002 rings and it goes to voicemail where I can leave voicemail and listen to it from 2002.
However, if I place call from the PSTN to the same number 2002 (or any other number in other sites etc) the call again rings in 2002 and goes to voicemail, unity cnx plays the greetings for 2002 and says record your message as usual. Everything up to point is fine, then when the time on the PSTN phone is showing around 14 seconds into the call unity starts playing, "to send this message press one", if I press one nothing happens.
I have rebuilt unity and cucm, even just configured the bare minimum in the lab and still getting the same result. I tried calling from E1 connection and T1 connection but with the same results.
I have run out of ideas...
Here is a call trace from an internal call:
CallData, 1, CallerId=2003, CalledId=2002, RedirectingId=2002, Origin=16, Reason=4, CallGuid=8B7859FD6C16417A9A07F507418DD25B, CallerName=, LastRedirectingId=2002, LastRedirectingReason=4, PortDisplayName=PhoneSystem-1-001
Application, 1, 2003, AttemptForward
State, 1, 2003, State - AttemptForward.cde!Dummy
State, 1, 2003, Event is [NULL]
Application, 1, 2003, PHTransfer
State, 1, 2003, State - PHTransfer.cde!LoadInfo
State, 1, 2003, Event is [TrueEvent]
Application, 1, 2003, PHGreeting
State, 1, 2003, State - PHGreeting.cde!PlayGreeting
Display, 1, 2003, Call answered if needed
Display, 1, 2003, Playing greeting for Subscriber:  hq2
Display, 1, 2003, No DTMF received
State, 1, 2003, Event is [RecordMsgEvent]
State, 1, 2003, State - PHGreeting.cde!RecordMsg
State, 1, 2003, State - PHGreeting.cde!RunEditMsg
Application, 1, 2003, -->MessageEditing
State, 1, 2003, State - MessageEditing.cde!CheckMsgMenuOpt
State, 1, 2003, Event is [EditMessageMenuEvent]
State, 1, 2003, State - MessageEditing.cde!PlayEditMenu
State, 1, 2003, Event is [HangupEvent]
State, 1, 2003, State - MessageEditing.cde!CheckMsgLength
State, 1, 2003, Event is [ManyEvent]
State, 1, 2003, State - MessageEditing.cde!SendMsg
State, 1, 2003, State - MessageEditing.cde!ConfirmSend
Application, 1, 2003, <--MessageEditing
Display, 1, 2003, Idle
Display, 1, , Dialing (MWI) '2002'
Display, 1, , Idle
and here is a trace from an external (PSTN) call
Trying 142.100.64.13, 5000 ... Open
CallData, 1, CallerId=911, CalledId=2002, RedirectingId=2002, Origin=16, Reason=4, CallGuid=CA3DFD90846C4FE7B0D68298A7698287, CallerName=PSTN Emergency, LastRedirectingId=2002, LastRedirectingReason=4, PortDisplayName=PhoneSystem-1-001
Application, 1, 911, AttemptForward
State, 1, 911, State - AttemptForward.cde!Dummy
State, 1, 911, Event is [NULL]
Application, 1, 911, PHTransfer
State, 1, 911, State - PHTransfer.cde!LoadInfo
State, 1, 911, Event is [TrueEvent]
Application, 1, 911, PHGreeting
State, 1, 911, State - PHGreeting.cde!PlayGreeting
Display, 1, 911, Call answered if needed
Display, 1, 911, Playing greeting for Subscriber:  hq2
Display, 1, 911, No DTMF received
State, 1, 911, Event is [RecordMsgEvent]
State, 1, 911, State - PHGreeting.cde!RecordMsg
State, 1, 911, State - PHGreeting.cde!RunEditMsg
Application, 1, 911, -->MessageEditing
State, 1, 911, State - MessageEditing.cde!CheckMsgMenuOpt
State, 1, 911, Event is [EditMessageMenuEvent]
State, 1, 911, State - MessageEditing.cde!PlayEditMenu
State, 1, 911, Event is [HangupEvent]
State, 1, 911, State - MessageEditing.cde!CheckMsgLength
Application, 1, 911, <--MessageEditing
State, 1, 911, State - PHGreeting.cde!AfterMsg
Display, 1, 911, Idle
Everyone's tags (4)
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Sounds like one way audio from PSTN to your Unity Connection, couple of things to check:
1. ensure your protocols are bound properly on the GW, i.e. SIP/H323/MGCP
2. Make sure IP routing is OK between Unity and the voice gateway
HTH,
Chris
HTH,
Chris
Hi Chris,
Your pointer gave me good food for thought and eventually it turned out to be an access list on the PSTN side blocking the PSTN phone from sending any auido. Appriciated.
Many thanks,
308
