Unity Connection Wav File
I have a department that is creating WAV files for Unity Conn they ar
e setting the sampling rate to the highest, Unity connection is not excepting this. What is the correct Sa
mpling rate for Unity? G.711 of course.
Thank you
Re: Unity Connection Wav File
This would be codec-based so for G.711, I believe that would be 64 kbit/s.
Hailey
Please rate helpful posts!
Actually, 64kbs would be the line rate. The sampling rate should be 8 kHz/second with 8 bit samples (thus 64kbps). You can use an audio editing application to check the sampling rate.
See the following table for sampling rate and other pertinent information:
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/connection/7x/design/guide/7xcucdg025.html#wp1069840
HTH.
Bill
Please remember to rate helpful posts.
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
4596
