Unity Connection web admin page question
We have Unity Connection Ver 7.1.3.  The default web admin page port number is 443 and/or 8443.  is there a way to change the port number?  if so, can I change the Admin page to say 543 and the CiscoPCA page to 643?
Thanks.
Mark
1 ACCEPTED SOLUTION
Re: Unity Connection web admin page question
You cannot modify anything related to the tomcat server which handles the GUI pages, this means you cannot change the ports used.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
I don't know of a facility to do this and; in any case, it would require that you be knowledgeable of which ports are used by the application as a whole and for what before changes are made.  See here for details:
www.cisco.com/application/pdf/paws/110172/cuc-netports.pdf
Hailey
Please rate helpful posts!
java
java
250
