Unity Connection
Hi All,
we have CUBE with unity connection. two companies are using one unity connection. we want to seperate voicemail system which if call comes in for campany A and hit unity connection, unity connection won't be able to dial extension in company B. totally seperate!
what is the best solution for this scenario? Create CSS and partition and assign to voice port which the voice port can't dial another voice port? or create two port groups in Unity connection?
thanks
Alex
1 ACCEPTED SOLUTION
Re: Unity Connection
the only way to achieve that is if you have CUC 7.0 which provides a similar concept to partitions and CSS. on previous versions this cannot be achieved as all DNs configured are available to any subscriber or user dialing in, even if you create 2 integrations unity will try to dial the DN and will recognize it
java
if this helps, please rate
java
www.cisco.com/go/pdi
1 REPLY
java
java
297
