Unity Connections 7.0 - Notification to Numeric Pager [VM# + CLID]
Trying to set-up pager notification to numeric pager that leaves voicemail # as well as CLID;
  • If I leave "Message Text" blank under SMTP Settings user gets CLID but is unable to determine if page is voicemail message or direct page;
  • Tried putting 58522 [VM #] in "From" field - same result - no CLID sent;
  • Is this still possible?
SMTP Settings
Nicole
1 REPLY
Re: Unity Connections 7.0 - Notification to Numeric Pager [VM# +
There should be a notification for pager.. looks like you are trying to use the SMTP notification.
Basically, there should be a number Unity call call, then pauses.. then CUC will enter the 58522.  The pager will go off and have the message 58522.
Pagers are odd because each have their own backend to control how the devices gets a message.
200
