Unity Connections 8 and CUCM 6?
We're running Unity Connections 71.2 and CUCM 6.1.4.  I need to upgrade both, but I'm waiting on CUCM for new hardware which may take months.
Unity Connections is having problems and needs constant reboots.  I'm trying to see if I can upgrade to Unity Connections 8.6 and keep CUCM 6.1.4.  Is that possible?  I couldn't find the relevant compatibility matrix.
Thanks!
1 ACCEPTED SOLUTION
See herehttp://www.cisco.com
See here
http://www.cisco.com/c/en/us/support/unified-communications/unity-connection/products-device-support-tables-list.html
java
if this helps, please rate
www.cisco.com/go/pdi
See here
java
Link worked, and version
Link worked, and version supported -- even all the way back to 5.x - wow!
29
