Unity Connections remote call sign-in issue.
I have some users that when they dial there DID from outside they hit there VM press star and are prompted for their sign-in number and pin. Then I have some users that do the same thing, but the greeting just continues to play. I am sure there is a simple fix to this, but I cannot seem to find it. Hoping someone out here can lead me in the correct direction.
I am running Unity Connection 8.6.2.
Thanks in advance,
Dave
Hall of Fame Super Red
Hi Dave, I would check the
Hi Dave,
I would check the following on a "working" vs "non-working" user;
User> Edit> Caller Input> * (star)> send to Sign-in
Cheers!
Rob
Please support CSC helps Kiva yes
https://supportforums.cisco.com/blog/12122171/cisco-support-community-helps-kiva
Both working and non-working
Both working and non-working boxes have * (star) pointing to the sign-in conversation under caller input.
All test calls have been done from a cell phone (iPhone specifically)
Dave
One gotcha that got me was if
One gotcha that got me was if the caller was using an analog cordless phone the DTMF was not being sent right.
35
