Unity Connections System Call Handler
Greetings,
I have a system call handler references another call handler when "4" is pressed which then is supposed to transfer to mailbox X2334. When I test I can leave a message however mailbox 2334 is empty. How is the reference from the second call handler to mailbox 2334 made?
Jon
1 ACCEPTED SOLUTION
from your first Call Handler, use caller input 4:
ACTION>USER With mail box and choose the user that has extension 2334
Please remember to rate useful posts, by clicking on the stars below.
Silver
Hello Jon,
I would require some clarification to understand the call flow, however getting to the point you want to dial key # 4 from the second call handler to reach the users mailbox.
If this is correct you would go to Call Management> System Call Handlers> select you Call Handler> Edit> Caller Input> Click on number 4> User with Mailbox > Either Attempt Transfer or Go Directly to Greetings.
Best Regard,
-D a  v   i    d     R      o       j        a         s          P           e            c             k
Thanks to both replies - the user with mailbox action worked perfectly.
Jon
251
