Unity Design Query: Same extension in different Partition
I have a query where I have 2 remote sites with the same extension range:
Site A: 1231000 to 1231999
Site B: 7891000 to 7891999
I think there is two ways to do it, first in CCM and unity, to use 7 digit extensions. The VM and MWI should work.
But I'm thinking can we leave the CCM as 4 digit extensions and use the two seperate VM profile's mask as 123XXXX and 789XXXX. I am able to leave a VM to the correct mailbox, but the MWI doesn't work.
I think the VM port must be able to reach both Site A and Site B phone partition, but the CSS is sorted in order, therefore it would never reach Site B partition.
Did I missed out something? Have anyone tried this before?
Thanks!
Eugene
Re: Unity Design Query: Same extension in different Partition
*Bump
Anyone has any experiences using Unity between 2 sites with similar extensions?
Eugene
Look at the document http://www.cisco.com/en/US/docs/voice_ip_comm/unity/401/integration/guide/ITCICM33.html
(CTRL-F in your web browser and search "multitenant").
Wojtek
Bronze
Your concerns are very valid. Take a look at the following:
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.1dde5bc3/0
I have heard rumors that a future Unity release will be Partition and Calling Search Space aware which will alleviate this kind of problem.
Thanks guys.
Hope the new release would solve this issue alright.
Eugene
113
