Unity does not responds to DTMF from Motorolla and Apple iPhones.
I have a H.323 gateway connected to PSTN and CUCM in other end, the CUCM is integrated with the Unity.
The set up is like, whenever my extensions are busy, the IVR setup in the unity must work.
PSTN CLOUD >> H.323 G/W >> CUCM >> UNITY
Things are working when the calls made from landline and mobile phones, but when a call made from Motorola mobile phones and Apple iPhone, the unity does not responds to the DTMF.
Call manager version - 6.1.2
Unity version : 5.0(1)
H.323 g/w version : c2800nm-advipservicesk9-mz.124-9.T3.bin
Anyone have an idea what could be the reason ?
Everyone's tags (5)
1 ACCEPTED SOLUTION
Silver
What are you using for your PSTN connection? PRI? SIP trunk? Analog line?
First, you will want to ensure you are receiving the DTMF at the gateway.  The debug commands will vary based on what kind of PSTN connection you have.
Silver
Hi Meade,
its a PRI line, i have tried the below debug output, but unable to get DTMF related logs...is there any other debug to capture the DTMF signal hitting the h.323 gateway?
debug vpm signal
debug vtsp session
debug vtsp dsp
debug voip ccapi inout
debug h245 asn1
debug voip rtp
debug cch323 rtp
debug h245 asn1
debug voip rtp
debug cch323 rtp
Silver
Try these-
debug vtsp dsp
debug voip rtp session named-event
Make sure you have term mon turned on if you are connecting via telnet/ssh.
If you still do not see anything, your carrier may not be sending the digits at all so you will need to work with them.
Brian Meade
426
