05-12-2010 08:13 AM - edited 03-15-2019 10:43 PM
I need to change the domain my voicemail only unity server sits in, I understand I have to run DIRT and rebuild. Just wanted to check this will restore all the user accounts in AD / Exchange even though it will be a new domain name?
Solved! Go to Solution.
05-12-2010 08:56 AM
Yes, these items will be restored. Take a look at the help for DiRT below which indicates that this is a supported scenario.
http://www.ciscounitytools.com/Applications/Unity/DIRT/DIRT.html
Hope this helps.
Brandon
05-12-2010 08:56 AM
Hope this helps.
Brandon
05-12-2010 09:09 AM
thanks for that
Its been a while since I have built one, does the unity need access to the callmanager during the build (apart from the integration part)?
05-12-2010 10:00 AM
No, no access to Callmanager needed except when you configure the integration.
Hope this helps.
Brandon
