07-11-2008 08:07 AM - edited 03-15-2019 11:54 AM
My client has a Unity 5.0 and would like the capabilitiy to manually control an emergency message that will play to incoming callers when they call the Main AA line, which is currently a callhandler in unity.
As mentioned above the client would like to be able to turn this greeting on and/or off when they want to.
Any thoughts would be greatly appreciated.
Thanks.
07-11-2008 08:29 AM
yes, use the greetings administrator to do that
look for CUGA or Cisco Unity Greetings Administrator
javalenc
if this helps, please rate
07-11-2008 09:33 AM
Hi Hugo,
Just to add a note to the good info from Jaime;
Changing Call Handler Greetings through the TUI with Unity
http://www.cisco.com/en/US/products/sw/voicesw/ps2237/products_tech_note09186a00801543ef.shtml
Hope this helps!
Rob
