Unity Express 3.1 Cannot Zero Out to Auto Attendant
I have a client that is using UE 3.1. The zero out number is configured as the Auto Attendant in both the Voice Mail > CallHandling > Voicemail operator number and in the individual voice mail boxes. When a caller hits zero the caller get the message that it is transferring to an extension but the call is disconnected.
If I configure the zero out number for a regular extension it transfers.
All help is appreciated.
Re: Unity Express 3.1 Cannot Zero Out to Auto Attendant
Since you have it configured on all the correct places.
I would insure that the AA number can be dialed and reached internally.
If not verify CME dial peers and CUE triggers.
If a custom script is being used I would try the Cisco default and test.
Debug ccsip messages for one bad call will shed some light on who is sending the bye CME or CUE.
If it is a customer script I would take a look at the Unity Express Custom Scripts Quick Start Guide here for detailed examples of custom call flow
http://www.cisco.com/en/US/partner/products/sw/voicesw/ps5520/products_tech_note09186a008041d950.shtml
Thanks for the advice. I was able to fix it by allowing sip to sip calls.
CME(config)#voice service voip
CME(conf-voi-serv)#allow-connections sip to sip
226
