Unity Express 8.5 - software Installation on a SM
Hi all,
    I want to install cisco unity but getting failed my 2921router conf i can ping from router to pc ftpser and from pc to router and SM1/0 ping too.
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
duplex auto
speed auto
interface SM1/0
ip unnumbered GigabitEthernet0/0
service-module fail-open
service-module ip address 192.168.1.5 255.255.255.0
service-module ip default-gateway 192.168.1.1
interface SM1/1
description Internal switch interface connected to Service Module
no ip address
ip route 192.168.1.5 255.255.255.255 SM1/0
service-module sm 1/0 install url ftp://192.168.1.20/cue-vm-k9.sme.8.5.1.pkg
SM_INSTALL-3-INST_SCRIPT_FAIL: Execution of script cue-vm-k9.sme.8.5.1.pkg.install.sre failed, installation aborted
Router#service-module sm1/0 session
Trying 192.168.1.1, 2067 ... Open
but nothing opening at all and if i hit enter then this came up
ServicesEngine boot-loader>
Router#service-module sm 1/0 status
Service Module is Cisco SM1/0
Service Module supports session via TTY line 67
Service Module is trying to recover from error
Service Module heartbeat-reset is enabled
Service Module is in fail open
Service Module status is not available
Module resource information:
  CPU Frequency: 1864 MHz
  Memory Size: 2530 MB
  Disk 0 Size: 500107 MB
  Disk 1 Size: 2055 MB
No install/uninstall in progress
Localstore Info - (0 apps)
ANY help
Thanks in Advance
2 ACCEPTED SOLUTIONS
Bronze
Sure - it's here http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel8_5/install/boothelp.html
It's missing one optional step though, you may need to install certificate-key into the module before step "Type boot helper to begin the installation".
To install the key (file name cue-vm-k9.sme.8.5.1.key for example), you need to enter command "install_key cue-vm-k9.sme.8.5.1.key" from the boot menu after you set IP addressing and TFTP server information there. It will download the key file into the module via TFTP.
_____ Please rate helpful posts Пожалуйста оценивайте полезные сообщения
Bronze
Can you see anything in the TFTP server logs?
Bronze
That's normal AFAIK.
Just use the helper installation process.
Bro can you explain lil steps how becoz never did before
thx in advance
Bronze
Bro i am still getting this error i tried very hard and i followed that doc but no luck
boot helper giving same error
ServicesEngine boot-loader> install_key cue-vm-k9.sme.8.5.1.key
Bootloader TFTP error UDP transmit error
cue-installer.sme.8.5.x
cue-vm-k9.sme.8.5.x.pkg
cue-vm-full-k9.sme.8.5.x.prt1
cue-vm-installer-k9.sme.8.5.x.prt1
cue-vm-langpack.sme.8.5.x.prt1
i do have have tftp and ftp server in my laptop up and running ping worked every were.
is this caus the problem ?
thanks in AD
Bronze
THKS bro Anti virus was doing his JOB
1425
