Unity EXpress + AIM Module + Callmanager
i want use cisco unity to work with the CallManager 7.0.
i have installed and configured the AIM module like described on the doc. but when i use the web interface to configure , i found that only CallManager Express is accepted not Callmanger.
the used version are :
unity> show version
unity uptime is 0 weeks, 0 days, 1 hours, 14 minutes
CPU Model: Celeron (Coppermine)
CPU Speed (MHz): 298.909
CPU Cache (KByte): 128
BogoMIPS: 587.77
SKU: Unavailable
Chassis Type: C2811
Chassis Serial: FHK1252F3X5
Module Type: AIM
Module Serial: FOC12204XVC
UDI Name: Not Available
UDI Description: Not Available
Compact Flash: 1GB
SDRAM (MByte): 256
unity> show software ?
dependencies Subsystem dependencies
directory directory
download download
licenses Terms and limits of operation
packages Programs and Options installed
versions Version information for the installed packages
unity> show software versions
Cisco Unity Express version (3.2.1)
Technical Support: http://www.cisco.com/techsupport Copyright (c) 1986-2008 by Cisco Systems, Inc.
Components:
- CUE Voicemail Language Support version 3.2.1.0
please can someone help me
thanks in advance
hicham
1 REPLY
Re: Unity EXpress + AIM Module + Callmanager
Most probably the license on CUE is for CME, you need to load one for CUCM
java
if this helps, please rate
java
www.cisco.com/go/pdi
313
