Unity Express - busy signal
Hi to all .
I have problem with AIM-CUE Script , when the outside caller dial-extension X and it's busy , they did not hear anythink
indicate that line is busy , it's possible to make choice for caller "the line is busy , if you want leave MSG dial x if you need call other ext. press * " ?
P.S : I don't need configure call-forward busy to VM in ephone-dn .
thank you .
Everyone's tags (1)
1 REPLY
Hall of Fame Super Gold
There is no way to do that with the standard CME features.
You can either configure DN with huntstop channel, or use my script "selective ringback" available on ciscoscripts.com
556
