Unity Express Caller ID not recognized
I have a problem with Cisco Unity Express.
When the user calls his mailbox from his own phone he is asked for his Extension ID followed by #.
Normally, the system should automatically detect the user ID if the call is from his own phone and it should only ask for the password.
Early it was working correctly.
I perhaps modify something in my CCME config but I really don't see what.
It seems that the caller ID is not recognized by Unity.
What are the requirements for Unity to recognize the caller ID?
Thanks in advance,
François
j-block
Level 4
Level 4
Make sure that you do this on the CUE module from the CME router enable prompt:
ser ser 1/0 sess (asumign cue is in 1/0)
[enter]
enable
[enter]
conf t
voicemail callerid
exit
wr
Now check if it has changed anything when you playback the voicemail left by an user.
This problem is now solved.
I removed the "dialplan-pattern" commands that I used and the problem disappeared.
Using it, the dn of the phone being presented to CUE as the expanded number was changed.
This then required a translation pattern to change it to back to the short extension number or using the secondary number in CUE to match the extended number.
