Community Member
Unity Express - how to avoid "post-greeting" message in English
Hi all,
please dont you know how to get rid of announcement "record your message at the tone..." which plays right after user-recorded announcement?
Im not from English speaking country and it confuses people, there is no language pack for our language.
I found this advice in forum
https://supportforums.cisco.com/message/1078313#1078313
but in my CUE 7.1 are no subscribers menus or class of services.
Thanks in advance for your hints.
Everyone's tags (5)
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: Unity Express - how to avoid "post-greeting" message in Engl
Hi there,
voicemail conversation caller recording-prompt
To enable playing a prompt to a caller to record a message, use the voicemail conversation caller recording-prompt command in Cisco Unity Express configuration mode. To disable the prompt, use the no form of this command.
no voicemail conversation caller recording-prompt
Syntax Description
This command has no arguments or keywords.
Defaults
The default is enabled (the system plays the prompt).
Usage Guidelines
The caller hears the following message after the recipient's greeting plays: "Record your message after the tone. When you are finished, hang up or press # for more options." Use this command to enable or disable the playing of this prompt.
To display the status of the caller recording-prompt, use the show running-config command. If the prompt has been disabled, the following line appears in the output:
The show running-config output will not display any status of the prompt if the prompt is enabled.
Examples
The following example disables playing the caller record-prompt:
se-10-0-0-0# config t
se-10-0-0-0(config)# no voicemail conversation caller recording-prompt
se-10-0-0-0(config)# end
se-10-0-0-0#
https://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel3_2/Command/v_cmds.html#wp1016219
Cheers!
Rob
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
https://supportforums.cisco.com/docs/DOC-8727
Hi there,
Syntax Description
Defaults
Usage Guidelines
Examples
se-10-0-0-0#
Cheers!
Rob
Community Member
     how can i disable the "please record your message" prompt on a specific mail baox level not on the system level, kindly advise.
1213
