unity express in SRST
Hello all,
I am having CUE Express AIM2-CUE, installed into 2811 router at one of branch.
Currently CUE is having CCM License file & it is integrated with CCM 7.x at HQ & working perfect.
If my branch router switch into SRST mode, my CUE stops working & it gives fast busy tone if i call from same branch internally or from PSTN. I have created following DP for CUE but still its giving fast busy tone.
dial-peer voice 8088 voip
destination-pattern 8088
session protocol sipv2
session target ipv4:10.0.24.250 (CUE IP)
dtmf-relay sip-notify
codec g711ulaw
no vad
My CUE config is following & my branch is having MGCP gateway i am having CUE 7.X.
ccn trigger jtapi phonenumber 8088
application "voicemail"
enabled
maxsessions 6
end trigger
ccn subsystem jtapi
ctiport 4221 4222 4223
ccm-manager address 10.0.24.20 10.0.24.21
ccm-manager credentials hidden "kqp8kECeSyDrgZAziRUcjPcs5XnGilj/Sd8ZZNgd+Y9J3xlk2B35j0nfGWTYHfmPSd8ZZNgd+Y9J3xlk2B35j0nfGWTYHfmPSd8ZZNgd+Y9J3xlk2B35j0nfGWTYHfmP"
end subsystem
can any body suggest what is the problem ?
Ahmed
Everyone's tags (4)
1 ACCEPTED SOLUTION
Blue
Hi Ahmed,
Since you are using CUCM license you also need to use SIP Subsystem and SIP trigger to make it work in SRST.
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_configuration_example09186a0080289ef0.shtml
Above link shows the desired configuration.
Ronak Patel
Please rate helpful posts by clicking stars below the answer.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Blue
Hi Ahmed,
Ronak Patel
Thanks Ronak,
It worked after SIP subsystem & SIP trigger
Ahmed
452
