Community Member
Unity express License issue - Voice mail not able to activate
I need to get clarify some items.
Unity Express verion 7.1.2
CME Version 7.0
IOS Version : c2800nm-ipvoicek9-mz.124-20.T1.bin
First i faced some issue in the unity express License installation, after that i went through following documents
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel7_1/install/installism.pdf
After that i got following prompts
Installing...Feature:VMIVR-VM-MBX...Successful:Supported
License Note:
Application will evaluate this change upon next reload
Installing...Feature:VMIVR-IVR-SESS...Successful:Supported
License Note:
2/2 licenses were successfully installed
0/2 licenses were existing licenses
0/2 licenses were failed to install
Please find the show informations also.... here i marked some of the informations.
CUE#  [0mshow license  [0K [4hap
  [0;1m [4l(INIT)
NCS-CUE E# #    [0mshow license ap [0K
  [2K
  [0;1m(INIT)NCS-CUE E# #    [0mshow license ap [0K
  [0;1m(INIT)NCS-CUE#  [0mshow license ap [0K       [4hst
  [0;1m [4l(INIT)NCS-CUE E# #    [0mshow license st [0K [4hat
  [2K [4l
  [0;1m(INIT)NCS-CUE E# #    [0mshow license stat [0K
  [0;1m(INIT)NCS-CUE#  [0mshow license stat [0K [4hu
  [0;1m [4l(INIT)NCS-CUE E# #    [0mshow license statu [0K [4hs
  [0;1m [4l(INIT)NCS-CUE#  [0mshow license status  [0K
  [0m(INIT)NCS-CUE E# #   show license status  [0K [4h? [4l
  application       License status for applications
  <cr>
  [0;1m(INIT)NCS-CUE#  [0mshow license status  [0K [4hap
  [0;1m [4l(INIT)NCS-CUE E# #    [0mshow license status ap [0K [4hplication
  [0;1m [4l(INIT)NCS-CUE#  [0mshow license status application  [0K
  [0m(INIT)NCS-CUE E# #   show license status application  [0K [4h? [4l
  ivr               License status for IVR
  voicemail         License status for Voicemail
  <cr>
  [0;1m(INIT)NCS-CUE#  [0mshow license status application  [0K [4hvoice
  [0;1m [4l(INIT)NCS-CUE E# #    [0mshow license status application voice [0K [4hmail
  [0;1m [4l(INIT)NCS-CUE#  [0mshow license status application voicemail  [0K
  [0m(INIT)NCS-CUE E# #   show license status application voicemail  [0K
voicemail disabled, ivr session quantity (4) is equal to or exceeds available ports (4)
  [0;1m(INIT)NCS-CUE#  [0m [0K
  [2KSYSTEM ONLINE
  [0;1mNCS-CUE E# #    [0m [0K
  [0;1mNCS-CUE E# #    [0ml [0K [4hi
  [0;1m [4lNCS-CUE E# #    [0mlicen [0K
  [0;1mNCS-CUE E# #    [0mlicense activate vo [0K
  [0;1mNCS-CUE E# #    [0mlicense activate voicemail mail [0K [4hboxes 275
  [0m [4lNCS-CUE E# #   license activate voicemail mailboxes 275 [0K
Count exceeds the platform maximum of 65
  [0;1mNCS-CUE#  [0m [0K
  [0;1mNCS-CUE E# #    [0mlicense activate voicemail mailboxes 275  [0K
  [0;1mNCS-CUE#  [0mlicense activate voicemail mailboxes 275  [0K             [4h40
  [0m [4lNCS-CUE E# #   license activate voicemail mailboxes 40 [0K
Current license already active, count saved for use at next reload
  [0;1mNCS-CUE E# #    [0ms [0K [4hh
  [0;1m [4lNCS-CUE E# #    [0mshow [0K
  [0;1mNCS-CUE E# #    [0mshow licen [0K [4hse in-use
  [0m [4lNCS-CUE E# #   show license in-use [0K
StoreIndex:  0    Feature: VMIVR-VM-MBX                      Version: 1.0
    License Type: Permanent
    License State: Active, In Use
    License Count: 30 /30
    License Priority: Medium
StoreIndex:  1    Feature: VMIVR-IVR-SESS                    Version: 1.0
    License Count: 6 /4
StoreIndex:  1    Feature: VMIVR-PORT                        Version: 1.0
    License Type: Evaluation
        Evaluation total period:  8 weeks  4 days
        Evaluation period left:  8 weeks  3 days
        Expiry date: Wed Dec  2 06:38:52 2009
    License Count: 60 /4
    License Priority: Low
    License Priority: None
        Expiry date: Wed Dec  2 06:32:23 2009
StoreIndex:  2    Feature: VMIVR-IVR-SESS                    Version: 1.0
    License State: Inactive
        Evaluation period left:  8 weeks  4 days
    License Count: 60 / 0
  [0mNCS-CUE E# #     [0K
  [0mNCS-CUE E# #    [0K
  [0mNCS-CUE E# #    [0K
  [0;1mNCS-CUE E# #    [0mshow lice [0K [4hnse in-use
  [0;1mNCS-CUE E# #    [0mshow license status [0K
  [0;1mNCS-CUE E# #    [0mshow license status a [0K [4hpplication
  [0m [4lNCS-CUE E# #   show license status application [0K
ivr enabled: 4 sessions
  [0;1mNCS-CUE E# #    [0mshow license status application  [0K
  [0;1mNCS-CUE#  [0mshow license status application  [0K
  [0mNCS-CUE E# #   show license status application  [0K [4h? [4l
  <cr>
  [0;1mNCS-CUE#  [0mshow license status application  [0K [4hvoic
  [0;1m [4lNCS-CUE E# #    [0mshow license status application voic [0K [4hemail
  [0;1m [4lNCS-CUE#  [0mshow license status application voicemail  [0K
  [0mNCS-CUE E# #   show license status application voicemail  [0K
I would like to know that how i can activate voice mail informations.....
Sunish.
Re: Unity express License issue - Voice mail not able to activat
I am also having the same issue. Has anyone fixed this yet or have a fix for it?
Community Member
You have 4 IVR channels
You have 4 IVR channels activated, which is equal to your available ports, then left no ports for AA or voicemail. Reduce the IVR channel to 2 or whatever it's suitable.
license activate ivr sessions 0
license activate voicemail mailboxes 30
license activate ports 4
write memory
reload
Community Member
write memory
reload
Community Member
write memory
reload
Community Member
this fixed my problem. Thanks
this fixed my problem. Thanks!
2475
