Community Member
Unity Express License Mailbox
hi,
I have purchase "NME-CUE " with "Unity Express License 50 Voice Mailbox-Auto Attendant-CCME", now Is the license installed already on CUE or I have to download it from cisco website and install it on CUE.
When I do this command on CUE
“show license status application”
it show me this message
“voicemail disabled, no activated mailbox license available
Ivr disable, no activated ivr session license available”
1 ACCEPTED SOLUTION
Re: Unity Express License Mailbox
Take a look at this procedure and see if it helps you get where you need to be:
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel7_1/install/upglic.html
HTH.
Bill
Please remember to rate helpful posts.
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
HTH.
Bill
Hall of Fame Super Red
Hi there,
I'll add one other link here to the great idea from Bill (+5 Mr. Bell)
Software Activation for Cisco Unity Express 7.1 and Later Versions
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel7_1/Licensing/CUELicensing_book.html
Cheers!
Rob
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
https://supportforums.cisco.com/docs/DOC-8727
408
