03-04-2014 12:39 PM - last edited on 03-09-2022 11:15 PM by smallbusiness
Hi team
Please can someone help , i configure unity express to call manager CTI port registred to the call manager , voice mail pilot and attended registred as well , but when i m calling the VOICE mail it's rings it's showing CTI port number but i received fast busy signal after the first ring
03-04-2014 12:50 PM
Can you post your CME and CUE config?
Yosh
03-04-2014 01:24 PM
voice-card 0
dsp services dspfarm
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
license udi pid CISCO2901/K9 sn FCZ173292T6
hw-module ism 0
hw-module pvdm 0/0
username SSIHD_ADM privilege 15 password 0 IPMAN%2012$
redundancy
interface Loopback0
no ip address
interface Embedded-Service-Engine0/0
no ip address
interface GigabitEthernet0/0
ip address 10.36.177.3 255.255.255.0
no ip route-cache
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.36.177.3
interface ISM0/0
ip unnumbered GigabitEthernet0/0
service-module ip address 10.36.177.4 255.255.255.0
!Application: CUE Running on ISM
service-module ip default-gateway 10.36.177.3
no keepalive
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface ISM0/1
description Internal switch interface connected to Internal Service Module
no ip address
interface BRI0/1/0
no ip address
isdn switch-type basic-net3
isdn point-to-point-setup
isdn incoming-voice voice
interface BRI0/1/1
no ip address
interface BRI0/3/0
no ip address
encapsulation hdlc
shutdown
interface Vlan1
no ip address
ip default-gateway 10.36.177.250
ip forward-protocol nd
ip http server
ip http secure-server
ip route 10.0.0.0 255.0.0.0 10.36.177.250
ip route 10.36.177.4 255.255.255.255 ISM0/0
control-plane
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/1/0
compand-type a-law
connection plar 1700
voice-port 0/1/1
compand-type a-law
voice-port 0/2/0
voice-port 0/2/1
voice-port 0/2/2
voice-port 0/2/3
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
dial-peer voice 50 voip
tone ringback alert-no-PI
destination-pattern 1...$
progress_ind setup enable 3
progress_ind alert enable 8
progress_ind connect enable 8
progress_ind disconnect enable 8
no modem passthrough
session target ipv4:10.97.131.2
incoming called-number .
dtmf-relay h245-alphanumeric
codec g711ulaw
dial-peer voice 100 pots
direct-inward-dial
dial-peer voice 1 pots
destination-pattern 9[2-9]......$
direct-inward-dial
port 0/1/0
dial-peer voice 2 pots
destination-pattern 905[0256].......$
direct-inward-dial
port 0/1/0
prefix 05
dial-peer voice 3 pots
destination-pattern 90[234679].......$
direct-inward-dial
port 0/1/0
prefix 0
dial-peer voice 4 pots
destination-pattern 900T
direct-inward-dial
port 0/1/0
prefix 00
dial-peer voice 5 pots
destination-pattern 9[19]..$
direct-inward-dial
port 0/1/0
dial-peer voice 6 pots
destination-pattern 9[68]00T
direct-inward-dial
port 0/1/0
dial-peer voice 11 pots
direct-inward-dial
port 0/1/1
dial-peer voice 12 pots
direct-inward-dial
port 0/1/1
prefix 05
dial-peer voice 13 pots
direct-inward-dial
port 0/1/1
prefix 0
dial-peer voice 14 pots
direct-inward-dial
port 0/1/1
prefix 00
dial-peer voice 15 pots
direct-inward-dial
port 0/1/1
dial-peer voice 16 pots
direct-inward-dial
port 0/1/1
dial-peer voice 52 voip
preference 5
destination-pattern 1741
dial-peer voice 51 voip
session target ipv4:10.36.177.4
gatekeeper
shutdown
call-manager-fallback
secondary-dialtone 9
max-conferences 8 gain -6
03-04-2014 01:37 PM
We need to look at your CUE configuration.
Yosh
02-10-2016 03:08 AM
What does it mean ?
1...$ ?
destination pattern 1...$
