Unity Express- Transfering call after leaving voice mail
I have cisco unity express version 8.6.1. I would like the calling person to get an option to transfer the call to the operator after leaving voicemail. Is this possible?
Mohamed Faizal
Everyone's tags (6)
2 ACCEPTED SOLUTIONS
Configure "voicemail operator
Hall of Fame Super Red
Hi Mohamed,
Just wanted to add a good Tech note to the excellent tip from Frank (+5 Frank )
This doc shows the required config/steps;
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_tech_note09186a00808c3896.shtml
Cheers!
Rob
"Everything is broken" - Bob Dylan
Hi Mohamed,
Cheers!
Rob
Thanks for your response,
That worked....
Is it possible for us to have an option for the calling party to press 0 before it gets trasfered to the operator. Now what happends is the call get trasfered directly....
Mohamed Faizal
Hall of Fame Super Gold
You can use an operator number that points to an AA with any options or flow you want.
Hi Mohamed,
This is most possible
The zerooutnumber command was deprecated in CUE 7.1 and replaced with caller-input
caller-flow caller-input
To specify the call flow for a specified caller input, use the caller-flow caller-input command in Cisco Unity Express mailbox configuration mode. Use the no or default form of this command to remove the configuration of the call flow.
caller-flow caller-input input {ignore | repeat-greeting | say-goodbye | skip-greeting | subscriber-signin | transfer-to E164Phone | transfer-operator}
no caller-flow caller-input input {ignore | repeat-greeting | say-goodbye | skip-greeting | subscriber-signin | transfer-to E164Phone | transfer-operator}
Syntax Description
input
Specifies the number between 0 and 9 that a caller must dial to initiate a transfer to another phone number.
ignore
Ignore the key stroke and continue to play the greeting uninterrupted.
repeat-greeting
Repeat the greeting from the beginning
say-goodbye
Play the goodbye message and then disconnect the call.
skip-greeting
Skip to the end of the current greeting.
subscriber-signin
Play the subscriber signin prompt.
Transfer to the specified E164 phone number if it is not blocked by the appropriate restriction table.
transfer-operator
Transfer to the operator. If no operator is defined, the key stroke is ignored and the greeting plays uninterrupted.
Command Default
None.
Command Modes
Cisco Unity Express mailbox configuration (config-mailbox)
Command History
Cisco Unity Express Version
Modification
7.1
This command was introduced.
Usage Guidelines
This command replaces the zerooutnumber command in releases 7.1 and later.
Examples
The following example configures the call flow for a mailbox to forward a caller to 555-0200 if the caller dials 2:
se-10-0-0-0# config t
se-10-0-0-0(config)# voice mailbox owner user8
se-10-0-0-0(config-mailbox)# caller-flow caller-input 2 transfer to 5550200
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel3_2/Command/c_cmds.html#wpxref15986
Configurable Caller Flow
Beginning in version 7.1, you can customize how the call flow precedes in response to keys pressed by the caller during a call. For each mailbox, the mailbox owner or system administrator can assign one of the following actions to the keys input by the caller:
Transfer the call to another number
Connect to the operator
Ignore the input
Repeat the greeting
Say good bye
Skip the greeting
Proceed with subscriber sign-in
These actions can be assigned only to single digit input by the user, such as the numbers zero through nine (0 - 9), the asterisk (*), or the pound sign (#).
You can also optionally restrict the transfers using the caller input feature by configuring the call-flow restriction table.
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel7_1/rel_notes/rel_notes.html#wp261582
Caller input
Enables callers to control how the call flow precedes by pressing keys. For each mailbox, the mailbox owner or system administrator can assign actions to the keys such as:
• Transfer the call to another
number
• Connect to the operator
• Repeat the greeting
•From the CLI: See Cisco Unity Express CLI Administrator Guide.
•From the GUI: Use the Voice Mail > Mailboxes option and the online help
Cheers!
Rob
723
