07-29-2012 12:05 PM - edited 03-16-2019 12:25 PM
I have a 2821 with NME-CUE running Unity Express 3.0.Since we are migrating our CUCM from 5.1 to 8.6 we would need to upgrade the CUE to version 8.0
Seek to know if any upgrade licenses need to be purchased for the Unity Express.We are purchasing Migration licenses for CUCM.
Rgds
Sumesh
Solved! Go to Solution.
07-29-2012 12:11 PM
You can obtain migration licenses in real time at:
https://tools.cisco.com/SWIFT/LicensingUI/migrateLicense?subGroup=CUEIVRFEAT
07-29-2012 12:27 PM
Hi Sumesh,
I'll just add this bit to the great info from my friend Paolo +5
When you upgrade to version 7.1 or later, you must replace your pre-CSL licenses with CSL licenses. You are required to migrate your licenses for mailbox features and port features. If you purchased the optional IVR features, you must also migrate your licenses for the IVR features. The migration procedure for each of these types of licenses are described in a separate section below.
Note If you are upgrading to the same of licensed features as before, the CSL licenses are free.
When you obtain licenses for features for Cisco Unity Express 7.1 or later, the licenses are available only in the increments shown below. The following types of licenses are available:
•Mailboxes (available only in increments of five)
•Ports (available only in increments of two)
•IVR (available only in increments of two)
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel7_1/Licensing/Using_CSL.html
Cheers!
Rob
"Always movin' ahead and never lookin' back" - Springsteen
07-29-2012 12:11 PM
07-29-2012 12:15 PM
Thanks Paolo
so that means I dont need to order anything...the upgrade is free ?
07-29-2012 12:27 PM
Hi Sumesh,
Cheers!
Rob
