Unity Express Voicemail allowed sessions.
trying to setup voicemail on our new CCME system but every time i call voicemail i get a busy signal. i pretty sure i have the setup correct for dialing into the the voicemail. when i do a "sh license status application" in the CUE command line i get this:
voicemail disabled, no activated port license available
ivr disabled, no activated ivr session license available
I'm suppose to have 2 licensed sessions, and i am wondering if having to install the unity express software on the module(did not come with the unity express OS) somehow wiped that out?
  • IP Telephony
2 ACCEPTED SOLUTIONS
 Hi Mbuyarski, looks like the
Hi Mbuyarski,
looks like the Voicemail license and port license is not activated.
Use the following command to check the current status of the license
show license in-use
If you have 2 voicemail and 2 port licenses, then use the following command to activate voicemail license
license activate voicemail mailboxes 2
license activate ports 2
then save the config and reload the module
Once the module is rebooted, use follwoing command to check if license is active or not
 show license in-use
For more information, use the following document for reference
https://supportforums.cisco.com/document/32076/cue-licensing-faq
Thanks & Regards, Mudit Mathur
VIP Purple
Hi, the best is to check the
the best is to check the BOQ u have ordered to Partner.
regds,
aman
Hi Mbuyarski,
show license in-use
 show license in-use
VIP Purple
Hi  Mbuyarski,[+5] to Mudit
Hi  Mbuyarski,
[+5] to Mudit for tips..
you can also run the command in CUE module and share output:
show license feature
show license status application ivr
show call-agent
show software versions
regds,
aman
VIP Purple
Hi,If the licenses have been
If the licenses have been loaded, can u try the command license modify priority VMIVR-PORT high and then, reboot.
regds,
aman
our partner is saying the
our partner is saying the unity module comes with 2 licenses,  but i'm guessing since the unity module did not come with any OS loaded that i had to load on it that maybe it didn't have those 2 we were suppose to have pre installed.
VIP Purple
regds,
aman
Thanks for the help i will
Thanks for the help i will work with our partner to get this figured out
ok i ran those command and
ok i ran those command and here is the output from the show commands after the reload FYI: i did load up the 10 voicmail licenses we have bought prior to the post.
CUE-BAY-PKC# sh license in-use
StoreIndex:  0  Feature: VMIVR-VM-MBX                      Version: 1.0
        License Type: Permanent
        License State: Active, In Use
        License Count: 10 /10
        License Priority: Medium
StoreIndex:  1  Feature: VMIVR-PORT                        Version: 1.0
        License Type: Evaluation
            Evaluation total period:  8 weeks  4 days
            Evaluation period left:  8 weeks  3 days
            Expiry date: Mon Jun 16 08:51:53 2014
        License Count: 60 /2
        License Priority: Low
CUE-BAY-PKC# sh license status application ivr
CUE-BAY-PKC# show call-a
CUE-BAY-PKC# show call-agent
Call-agent:         CUCME
CUE-BAY-PKC# show software versions
Cisco Unity Express version (8.6.7)
Technical Support: http://www.cisco.com/techsupport Copyright (c) 1986-2013 by Cisco Systems, Inc.
Components:
 - CUE Voicemail Language Support version  8.6.7
CUE-BAY-PKC#
well its lets me into the voicemail now so everthing appears to be working but as you can see it looks like i just have a eval license. so i'm thinking i need to talk to our partner more on why we dont have port licenses.
140
