Unity Express
How can I do to telnet Unity Express (NM-CUE) remotely?
I'm in site A and the NM-CUE is in Site B, I need upgrade language and I can't telnet to NM-CUE, just GUI. It's normal?
Telnet to the router at Site B. Once in the site B router, type the following:
service-module service-engine x/x session
(You can do show ip interface brief to get the slot the CUE is in and replace the x/x accordingly)
or if you have a newer CUE model, type
service-module integrated-service-engine x/x session
That should get you in.
Hope that helped, if so please rate.
To add to the good advice by Kenneth, you can also telnet directly, IP of the router, port 2194.
