Unity failover time during shutdown of primary server
Hi Team,
I have tested following scenario and the failover unity server took 70-80 sec to answer the call.
Scenario:
I have shutdown the active unity server, then from the ip phone i was trying to dial the voice mail pilot number and keep ringing,failover unity server took 70-80 seconds the answer the call.
Is it normal behaviour or i have to fine tune the configuration?
Ashraf
Re: Unity failover time during shutdown of primary server
Hi there,
Intervals for Failover and Failback
Failover Interval
When  failover occurs, the time it takes for the secondary server to begin  answering calls typically depends on what causes failover as described  below;
Network outage
The  secondary server begins answering calls after waiting for the number of  keep-alive events set in the Missed Events Before Failover field in the  Failover Monitor. The time required depends on the value of the field  and on the value of the Interval (ms) field.
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/403/failover/guide/ex/FG_040.html#wp1110099
HTH, Please rate if so.
Justin
Hi Justin,
My scenario is I have shutdown the Primary server then the secondary server took 70-80 sec to answer the call.
Is it normal behaviour?
Ashraf
137
