Community Member
Unity Failover
I need to rebuild my secondary Unity because some SQL files are not in the same drive as the primary. Do I need to remove the secondary from the primary Unity and if yes can you tell me how?
thanks
Green
Re: Unity Failover
YEs, then reinstall the secondary and follow the installation guide for adding secondary server. Here is the doc for removing secondary
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/42/upgrade/guide/dom/ru_130.html#wp1227467
Community Member
Re: Unity Failover
thank you for your answer.
113
