Unity Fails when the CUCM Publisher is Down and Subcriber Works
I have a CUCM 6.1 (5) Cluster and Unity Conection.
The proble is When the publisher is Down and subscriber  works, the user press VM Button is not available.
But when the publisher is work and the user is avialable.
so
On the unity I configure in the telephony integration
Port Group th e Two servers of CUCM Cluster.
and The Phone system The two AXL Servers
and restart the servers.
1 REPLY
Re: Unity Fails when the CUCM Publisher is Down and Subcriber W
Is the hunt list configured with a CCM group that fails over to SUB?
Are ports registered?
Is CUC configured to try both servers in the integration?
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
189
