UNITY Full Disk
Hello Guys, I have configured two unity servers for voice mail. The problem is that the users have almost full the hard disk partition in both servers (they are independet one of echother) I have notice that the hard disks have another partition and that ones are empty. Is there a way I can use that partitions to store mail boxes?
Thank you for your help.
Re: UNITY Full Disk
With Cisco Unity version 4.0, users cannot retrieve voice mail and receive the The log file for database UnityDB is full error message
http://www.ciscotaccc.com/kaidara-advisor/voice/showcase?case=K49707136
Moving Exchange Message Stores and Transaction Logs to an Alternate Drive
http://www.cisco.com/en/US/products/sw/voicesw/ps2237/products_tech_note09186a00800c6f5f.shtml
java
if this helps, please rate
java
www.cisco.com/go/pdi
Re: UNITY Full Disk
Will this documentation will help with unity 5.0?
Re: UNITY Full Disk
yes, that config does not change
java
java
322
