Unity gurus -- call handler issue
Greetings!
So I'm in the middle of setting up a CCM 8.5 and Unity Connection 8.5 enviorment.  I've setup my call handler, and assigned extensions to them.
Issue -- When I dial the main number for the call handler (Assigned extension 6752) the system prompts me to enter my id as if i'm signing in instead of going to the call handler.  I'm sure it's something simple somewhere, what am I missing?
Everyone's tags (2)
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Loging to Unity Connection Admin Page, go to Routing Rules and ensure you do not have something defined for this 6752 number.
Is the issue only if you can this call hanlder, what if you call others or if you can another phone that forwards you to VM?
Chris
Hall of Fame Super Red
Hi Marcus,
In most cases I would set up 6752 as a CTI-RP in CUCM with a Call Forward All
to Unity Connection. Is this how you are routing calls from CUCM to CUC?
Cheers!
Rob
Re: Unity gurus -- call handler issue
Hi Rob,
I currently do have the 6752 setup as a Translation Pattern in CUCM with all calls being forwarded to voicemail_css
Hi Marcus,
On the CTI-RP page I see 6752 listed twice with two different partitions. Is this by design?
Cheers!
Rob
Yup! We have 2 seperate sites, 1 partition transfers to 6752 on site 1, second partion transfers to 6752 on site 2
is this SIP or SCCP VM integration? If SIP make sure you have Diversion Header checked on your SIP trunk, and not using "External phone number mask" on the Route Pattern.
Also, check your UCON Forwarding Routing Rules.
HTH,
Chris
All SCCP.
Did you look at your Routing Rules on UCON?
Chris
Chris are you refering to the CTI route points? Or what specifically do you want me to look at?
Chris
Hi Chris,
There was a forward routing rule, that was not referencing 6752.  I removed it, and the calls are going to the call handler now (weird)
Chris got the point!
Now to figure out how to configure the routing without screwing up my phone trees! thanks guys
Hi Marcus,
I'm sorry to be so dense here, but this part lost me completely
Are you saying there are 2 - 6752 Call Handlers??
Maybe if you could explain the call flow and relation to the Partitions I might clue in.
Sorry man!
Rob
Hi Rob!
We have two 6752 Call handlers.
SJC partition -- 6752 -- SJC Call Handler for the SJC Campus
MVC Partion -- 6752 -- MVC Call Handler for the MVC Campus
Before, both unity servers were seperated.
The new setup the unity servers are in a cluster.  I've tried removing the 6752 reference from the MVC Call handler, on the off chance that there was a conflict, but that doesn't resolve the issue (Which is why I think it's something simple that im missing)
One additional sympton! I have some voicemail boxes setup, when I dial them, it does not go to the voicemail box but sends the call to the login prompt as well.  It has to be something simple doh!
662
