Community Member
Unity integration
Hi all,
We are looking to integrate our current PBX Meridian system with our Unity solution.
My question is; will the message waiting indicators still work on our Meridian numbers while integrated with Unity?
Hall of Fame Super Red
Re: Unity integration
Hi Jamie,
Yes, MWI is fully supported in this integration :)
Cisco Unity Configuration Guides
http://www.cisco.com/en/US/products/sw/voicesw/ps2237/products_installation_and_configuration_guides_list.html
Nortel Meridian 1/PBXLink Integration Guide for Cisco Unity 5.0
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/5x/integration/voice_card/guide/nopbcu5x.html
Setting Up a Nortel Meridian 1 Digital PIMG Integration with Cisco Unity
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/5x/integration/pimg/guide/cuintpimg120.html
Hope this helps!
Rob
Community Member
Thanks for the reply Rob.
If we go down the PBX link box route can the Unity servers not pick up caller info from the calling number?
Are the link boxes essential?
Jamie
Hi Jamie,
It is the link boxes that provide the CLID/MWI etc. between Unity and the Nortel. You can also use the PIMG or TIMG integration setups. But all three scenarios require a "third party" box/boxes to enable the communications between these two systems.
Cheers!
Rob
Community Member
Thanks for the info Rob very helpful
165
