Community Member
Unity + language utilisation for user
hello,
i have installed unity 4.2(1) with success.
i want to give the possibility for the subscriber to access (configure) voice message from the ip phone by french language.
please help how i can do that?
thanks in advance
hicham
1 ACCEPTED SOLUTION
Re: Unity + language utilisation for user
the subscriber template has the language you can use for newly created subscribers, for subscribers already created in the profile page you can set the language
do you already have the languages installed?
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
1 REPLY
javalenc
java
107
